Introdução
The line of a weed whacker will often shorten and break due to use over time. Follow this guide to change the line on your Black and Decker 12-inch Grass Hog Automatic Feed String Trimmer (Model No.GH400).
Before beginning this repair, make sure your weed whacker is off and not connected to power before trying to replace the line. You'll need 1.7mm of line for the trimmer and a pair of scissors.
O que você precisa
To prepare a new line for your weed whacker, use your utility scissors and cut a piece of line between 30 cm and 50 cm long.
Uma outra pessoa concluiu este guia.
