Ir para o conteúdo principal
Black+Decker HSV420 batteries Replacement
O que você precisa
  1. Black+Decker HSV420  batteries Replacement, batteries: passo 1, imagem 1 %32 Black+Decker HSV420  batteries Replacement, batteries: passo 1, imagem 2 %32
    • Remove dust collector (while you’re there, clean it)
  2. Black+Decker HSV420  batteries Replacement: passo 2, imagem 1 %32 Black+Decker HSV420  batteries Replacement: passo 2, imagem 2 %32
    • Remove five (5) phillips screws 003-004
  3. Black+Decker HSV420  batteries Replacement: passo 3, imagem 1 %32 Black+Decker HSV420  batteries Replacement: passo 3, imagem 2 %32 Black+Decker HSV420  batteries Replacement: passo 3, imagem 3 %32
    • Split case 005 and lift off 006 revealing electronics board 007
  4. Black+Decker HSV420  batteries Replacement: passo 4, imagem 1 %32
    • Lift motor assembly from plastic body. Clip tie-wrap 008 and disconnect small white connector from electronics board 007 (picture 008 disappeared, but the tie wrap is the only one in there)
  5. Black+Decker HSV420  batteries Replacement: passo 5, imagem 1 %32
    • Disconnect red battery connector and white motor connector 009
  6. Black+Decker HSV420  batteries Replacement: passo 6, imagem 1 %32 Black+Decker HSV420  batteries Replacement: passo 6, imagem 2 %32
    • Remove gasket and fan shield 010-011
  7. Black+Decker HSV420  batteries Replacement: passo 7, imagem 1 %32
    • Remove two (2) screws to remove motor 012
  8. Black+Decker HSV420  batteries Replacement: passo 8, imagem 1 %32
    • Note the holes into which motor mount screws go 013
  9. Black+Decker HSV420  batteries Replacement: passo 9, imagem 1 %32
    • Remove three (3) screws from the battery carrier 014
  10. Black+Decker HSV420  batteries Replacement: passo 10, imagem 1 %32
    • Disconnect the long white connector from the electronics board
    • Split the carrier to remove the button the electronics board. 015
  11. Black+Decker HSV420  batteries Replacement: passo 11, imagem 1 %32
    • Note locations of insulating tape and remove them, two from each side. 016 HEED WARNING ABOUT SHOCK!
  12. Black+Decker HSV420  batteries Replacement: passo 12, imagem 1 %32
    • Pull temperature probe, that is connected to two green wires, out of assembly 017
  13. Black+Decker HSV420  batteries Replacement: passo 13, imagem 1 %32 Black+Decker HSV420  batteries Replacement: passo 13, imagem 2 %32 Black+Decker HSV420  batteries Replacement: passo 13, imagem 3 %32
    • Cut thin ORANGE wire about a cm from heat shrink. cut thin BLUE wire about a cm from heat shrink. 018 cut thin WHITE wire about a cm from heat shrink. cut thick BLACK wire about ½ cm from heat shrink. 019 cut thick RED wire about ½ cm from heat shrink. 020
  14. Black+Decker HSV420  batteries Replacement: passo 14, imagem 1 %32 Black+Decker HSV420  batteries Replacement: passo 14, imagem 2 %32
    • cut thin BLACK wire from fuse next to the battery heat shrink (two places) 021-022
  15. Black+Decker HSV420  batteries Replacement: passo 15, imagem 1 %32 Black+Decker HSV420  batteries Replacement: passo 15, imagem 2 %32
    • Slide the right side plastic carrier off of the batteries. 023 Note that two connectors are loose. So that you can determine the orientation of the batteries (where + or - goes) in the carrier, maintain the orientation while you slide the three batteries out of the left carrier. 024
    • Similarly, slide the one battery out of the left carrier. (note that there is an unused battery position.) I am going to give names to the batteries:
    • a Battery that is by itself. When looking from the motor, + is on the left
    • b Battery closest to the motor, + is on the right
    • c Battery in the middle of the three, + is on the left
    • d Battery farthest from the motor, + is on the right
    • For each battery, note which side is +, the location and where the + end goes. To ensure that you know which end is +, it is recommended that you check this with a voltmeter. And you can satisfy your curiosity about the voltage of the batteries. Sometimes are so bad they reverse polarity, but that voltage would be very low.
  16. Black+Decker HSV420  batteries Replacement: passo 18, imagem 1 %32 Black+Decker HSV420  batteries Replacement: passo 18, imagem 2 %32
    • Take the old batteries to the place where you recycle batteries. Unpack and check voltage of new batteries (NCR 18650B, 3.6V, 3000mAhr, welded on leads, voltage less than 3V probably indicates a bad battery) 025-026
  17. Black+Decker HSV420  batteries Replacement: passo 19, imagem 1 %32
    • Put the new batteries into the left half of the carrier, ensuring the + of the battery is in the same direction as its predecessor. 027
  18. Black+Decker HSV420  batteries Replacement: passo 20, imagem 1 %32
    • Put the right half of the carrier over the batteries and slide into place. Do not put in the screws, yet, you still need to put in the button and the electronics. 028
  19. Black+Decker HSV420  batteries Replacement: passo 21, imagem 1 %32 Black+Decker HSV420  batteries Replacement: passo 21, imagem 2 %32 Black+Decker HSV420  batteries Replacement: passo 21, imagem 3 %32
    • Connecting the fuse. The fuse is between + “a. Battery” and - “b. Battery” and should still be on the left carrier.
    • Very carefully peel off the tape that holds the fuse to the left carrier with the hope it can be reused. The purpose of the tape is to keep the fuse from rattling. Not so much as to reduce noise, but to prevent the connection from breaking
    • Strip about 1cm of heat shrink from each lead of the fuse
    • Make a U-bend at the end of each fuse lead 029
    • Ensure that the + lead of “a. Battery” will bend into the gap (see picture 030) This would be a good time to ensure that all of the other batteries.
    • “b. Battery” lead points to “c. Battery” “c. Battery” lead points to “d. Battery” “d. Battery” lead points to “c. Battery”
    • Cut red + lead of “a. Battery” leaving about 4cm. 031 Strip 1cm from lead. Tin lead
  20. Black+Decker HSV420  batteries Replacement: passo 22, imagem 1 %32 Black+Decker HSV420  batteries Replacement: passo 22, imagem 2 %32
    • connecting fuse, continued
    • Put about 1cm of heat shrink over the lead a push it near to the battery 032
    • Wrap the tinned lead 360° around the U in the fuse lead This is a one shot deal: Using the linemen’s pliers, crimp the U bend tight. The lead wire from the battery should not move. Solder the joint. Do not dwell with the soldering iron on the connection! 033
    • Slide the heat shrink over the joint and shrink it with heat (I used the soldering iron)
  21. Black+Decker HSV420  batteries Replacement: passo 23, imagem 1 %32 Black+Decker HSV420  batteries Replacement: passo 23, imagem 2 %32
    • This is probably a good time to secure the fuse to the carrier. 034-035
  22. Black+Decker HSV420  batteries Replacement: passo 24, imagem 1 %32 Black+Decker HSV420  batteries Replacement: passo 24, imagem 2 %32 Black+Decker HSV420  batteries Replacement: passo 24, imagem 3 %32
    • The orange wire needs to connect the the - of “b.Battery”, too. Push the thin blue and thin orange wire through the carrier. This is a good time to push the temperature sensor on the green wires into the carrier.
    • Trim and tin both the orange and blue wires Put a 2cm length of heat shrink over each of the orange and blue wires. Cut the - lead of the “b. Battery” leaving about 3cm
    • Strip 2cm of the lead and tin. Wrap the tinned lead 360° around the fuse lead, leaving a bit for the orange wire. Crimp the fuse lead Create a U on the “bit” of lead. Create a U on the orange wire Loop the U’s together, crimp with needle nose pliers and solder both joints, remembering not to dwell on the fuse lead 038
  23. Black+Decker HSV420  batteries Replacement: passo 25, imagem 1 %32
    • Slip the heat shrink, as best you can, over both joints and shrink 039
  24. Black+Decker HSV420  batteries Replacement: passo 26, imagem 1 %32
    • Solder + “c. Battery”, - “d. Battery” and thin blue wire Cut the leads of the battery wires to about 3cm , strip about ½ cm, twist together and tin.. Make a U in this joint and in the blue wire, loop U’s together, crimp with needle nose pliers, solder joint. Slip heat shrink over solder joint and shrink 040
  25. Black+Decker HSV420  batteries Replacement: passo 27, imagem 1 %32
    • Solder + “b. Battery”, - “c. Battery” and thin white wire Similar to previous, but make battery leads 5cm 041
    • Solder the battery connector red to + “d. Battery” and black to - “a.Battery” leads Cut battery leads to 3cm Each lead, trim, tin, 1.5cm heat shrink, loop, crimp, solder, slide heat shrink, shrink 041 Replace insulators over battery ends
  26. Black+Decker HSV420  batteries Replacement: passo 29, imagem 1 %32
    • REASSEMBLY -- You're now dealing with a ~15VDC battery pack! If shorted, it will do serious damage or catch afire!
    • Split battery carrier slightly and slip in electronics board 042 Align button and squeeze together battery carrier. Screw battery carrier together with three (3) screws Attach motor with two (2) screws
    • Connect long thin white connector to electronics board (it is keyed, DO NOT FORCE IT!) Connect motor wires to electronics board, white connector,keyed, tab towards center CAREFUL, MOTOR MIGHT START Judiciously hold the assembly while making the connection. Connect battery wires to electronics board, red, keyed tab towards center.
    • Test Hold sides of assembly, Be prepared for fan to start Press on button, fan should spin Press again to turn off. If these steps don’t happen, you did something wrong and your device is probably bricked.
    • Replace fan shield, large boss (as opposed the the small boss) away from electronics board Replace gasket Connect the white connecter from the housing to the electronics board.
    • Place assembly into housing. This gets a little tricky as it does not have a solid fit. Basically, the large square boss, away from the electronics board, that is part of the gasket goes into a receiving cavity in the housing. Place the cover and secure with five (5) screws.
Conclusão
It worked for me. Just waiting for the 6 hour charge of new batteries
5 outras pessoas executaram este guia.
Gregg Ferry
Membro desde: 10/21/17
1.427 Reputação
Autoria de 3 guias
15 comentários
Thanks so much! My vacuum couldn’t run for more than 2 mins, and following this guide I was able to to resurrect it.
It’s strange that old battery has good voltage but just wouldn’t run, hope the new batteries would last.
Bin Guo - Responder
Your are the MAN! Thank you
steve vaccaro - Responder
It worked for me. Good job on the guide.
Jeff Y - Responder
Thank you, Il works verry fine. A littel bit trickey, you will need some skil.
Gaétan legault - Responder
Replace the battery of BLACK+DECKER HSV420 VACUUM, can you tell me which one is correct? Because there are 2 models in your replacement step, 1×Set of4 NCR18650B 3.6V, 3000mAhr and 1×Set of4 NCR18650 3000mAhr. Waiting for your reply!
Thank you.
Jamed - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 25
Últimos 30 dias: 93
Duração total: 11,515
