Introdução
If any issues are arising inside your Bissell Zing 2156A, or you simply want to replace the casing, this guide will assist in taking it apart.
The casing is a extruded plastic shell, with other smaller plastic bits coming out of it. The casing is held in place by screws and small "snap-fit" fasteners. This guide starts with the removal of the rear wheel.
Overall, this assembly is safe to disassemble and reassemble.
O que você precisa
Remove the dust tank, so the vacuum can lie upside down easily.
Press the grey button while pulling up.
Remove the two 18.1 mm screws using a Phillips #0 screwdriver.
Remove the four 18.1 mm screws under the wheels using a Phillips #0 screwdriver.
Uma outra pessoa concluiu este guia.
