Introdução
Is your Bissell SpotClean ProHeat 5207U not spraying water? It could be because of a failing water pump. Follow this guide to replace the water pump for your Bissell SpotClean ProHeat 5207U.
O que você precisa
Remove the marked 19.7 mm screws on the underside of the device using the Phillips #00 screwdriver.
