Ir para o conteúdo principal
Bissell SpotClean ProHeat 5207U Water Pump Replacement
O que você precisa
  1. Bissell SpotClean ProHeat 5207U Water Pump Replacement, Water Pump: passo 1, imagem 1 %32 Bissell SpotClean ProHeat 5207U Water Pump Replacement, Water Pump: passo 1, imagem 2 %32
    • Ensure the device is unplugged.
    • Make sure that you have removed both the clean and dirty water tank so that you can unscrew the proper screws.
    • Remove the marked 19.7 mm screws on the underside of the device using the Phillips #00 screwdriver.
  2. Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 2, imagem 1 %32 Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 2, imagem 2 %32 Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 2, imagem 3 %32
    • Remove the plastic top located where the dirty water tank was previously situated.
    • Using the Phillips #00 screwdriver, unscrew the three 17.2 mm screws.
    • Remove the plastic lip that was previously held by the screws.
  3. Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 3, imagem 1 %32 Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 3, imagem 2 %32
    • Using pliers, pinch the hose clamp tabs together, then remove the clamp.
    • Remove the water hose from the water pump.
  4. Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 4, imagem 1 %32 Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 4, imagem 2 %32
    • Remove the green wire by pulling it away from the pump.
    • Be careful not to bend where the wire is plugged into.
  5. Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 5, imagem 1 %32 Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 5, imagem 2 %32
    • Pull the clear hose away from the pump until it is removed.
  6. Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 6, imagem 1 %32 Bissell SpotClean ProHeat 5207U Water Pump Replacement: passo 6, imagem 2 %32
    • Remove the zip tie from the water pump.
    • Replace the old water pump with the new water pump.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 136
