Ir para o conteúdo principal
Bissell SmartClean 1605 Roller Brush Replacement
O que você precisa
  1. Bissell SmartClean 1605 Roller Brush Replacement, Roller Brush: passo 1, imagem 1 %32
    • Make sure your device is powered off.
  2. Bissell SmartClean 1605 Roller Brush Replacement: passo 2, imagem 1 %32
    • Gently flip device over.
  3. Bissell SmartClean 1605 Roller Brush Replacement: passo 3, imagem 1 %32 Bissell SmartClean 1605 Roller Brush Replacement: passo 3, imagem 2 %32 Bissell SmartClean 1605 Roller Brush Replacement: passo 3, imagem 3 %32
    • Remove plastic plate cover to reveal brush roller.
  4. Bissell SmartClean 1605 Roller Brush Replacement: passo 4, imagem 1 %32 Bissell SmartClean 1605 Roller Brush Replacement: passo 4, imagem 2 %32
    • Remove brush roller from its slots on either side.
    • Apply pressure to one side and pull the roller out of its opposite slot.
    • It's like taking out a spring loaded toilet paper holder.
Conclusão
Austin Maranville
Membro desde: 09/26/17
117 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S7-G4, Banghart Fall 2017 Membro de Cal Poly, Team S7-G4, Banghart Fall 2017
CPSU-BANGHART-F17S7G4
Membros da 5
Autoria de 5 guias
13 comentários
What if mine don't feel spring loaded and the brushe seems like it was just wants to fall out
Brian - Responder
I'm having the same issue. The spring is not reloading to the brush just falls out
Rachel -
Same issue with mine. Took it apart and found that the side with spring loaded holder was broken.
Ryan Beaudre - Responder
I am having the same issue it’s like a part is missing for the pin side not the square sides to hold the brush roll in place.
Geoffrey Fraser - Responder
I have the same issue…it seems that the spring part was lost.have anyone of you find a replacement parts?
Mazinger Z - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 1,031
