Ir para o conteúdo principal
Bissell Powerglide Cordless Release Button Replacement
O que você precisa
  1. Bissell Powerglide Cordless Release Button Replacement, Release Button: passo 1, imagem 1 %32 Bissell Powerglide Cordless Release Button Replacement, Release Button: passo 1, imagem 2 %32
    • Press the release button while pulling up on the head of the vacuum to remove the head.
  2. Bissell Powerglide Cordless Release Button Replacement: passo 2, imagem 1 %32
    • Using a Phillips head screwdriver, unscrew the four screws holding the panel to the shaft of the vacuum.
  3. Bissell Powerglide Cordless Release Button Replacement: passo 3, imagem 1 %32 Bissell Powerglide Cordless Release Button Replacement: passo 3, imagem 2 %32
    • Pry the panel up using a spudger and pull up firmly just enough to see the clips of wire on the sides.
  4. Bissell Powerglide Cordless Release Button Replacement: passo 4, imagem 1 %32
    • Remove the wire clips on both sides of the shaft.
  5. Bissell Powerglide Cordless Release Button Replacement: passo 5, imagem 1 %32
    • Pull the top piece out of the shaft.
  6. Bissell Powerglide Cordless Release Button Replacement: passo 6, imagem 1 %32 Bissell Powerglide Cordless Release Button Replacement: passo 6, imagem 2 %32 Bissell Powerglide Cordless Release Button Replacement: passo 6, imagem 3 %32
    • Pinch the two pairs of plastic catches (circled in the picture) to release the button.
Conclusão
Khanh Fleshman
Membro desde: 01/28/18
133 Reputação
Autoria de 1 guia
Equipe
CPSU-BANGHART-W18S21G2 Membro de CPSU-BANGHART-W18S21G2
Community
1 Membro
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 157
