Ir para o conteúdo principal
Bissell Powerglide Cordless Debris Canister Funnel Replacement
O que você precisa
  1. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: passo 1, imagem 1 %32 Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: passo 1, imagem 2 %32 Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: passo 1, imagem 3 %32
    • Remove the gray motor unit by twisting it so that the black triangle moves from the "locked" to the "unlocked" position.
  2. Bissell Powerglide Cordless Debris Canister Funnel Replacement: passo 2, imagem 1 %32
    • Remove the filter from the dirt canister.
  3. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Debris Canister Funnel: passo 3, imagem 1 %32
    • Separate the cyclone assembly from the dirt tank by twisting the pieces counterclockwise.
  4. Bissell Powerglide Cordless Debris Canister Funnel Replacement: passo 4, imagem 1 %32
    • Use a Phillips head screwdriver to remove the three screws from the bottom of the cyclone assembly.
    • Remove the bottom of the assembly.
  5. Bissell Powerglide Cordless Debris Canister Funnel Replacement: passo 5, imagem 1 %32 Bissell Powerglide Cordless Debris Canister Funnel Replacement: passo 5, imagem 2 %32
    • Twist the clear plastic capsule with the fins counterclockwise to remove it.
  6. Bissell Powerglide Cordless Debris Canister Funnel Replacement: passo 6, imagem 1 %32
    • Twist the blue parts counterclockwise with a good amount of force to remove them.
Conclusão
Joseph Adam Johnson
Membro desde: 02/05/18
511 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team S21-G2, Banghart Winter 2018 Membro de Cal Poly, Team S21-G2, Banghart Winter 2018
CPSU-BANGHART-W18S21G2
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 208
