Ir para o conteúdo principal
Bissell PowerForce Compact Belt Replacement
O que você precisa
  1. Bissell PowerForce Compact Belt Replacement, Belt: passo 1, imagem 1 %32 Bissell PowerForce Compact Belt Replacement, Belt: passo 1, imagem 2 %32 Bissell PowerForce Compact Belt Replacement, Belt: passo 1, imagem 3 %32
    • Remove the 5 screws from the brush plate with the phillips screwdriver.
  2. Bissell PowerForce Compact Belt Replacement: passo 2, imagem 1 %32 Bissell PowerForce Compact Belt Replacement: passo 2, imagem 2 %32
    • Lift off the brush plate by grabbing both ends of the plate and lifting the plate up.
  3. Bissell PowerForce Compact Belt Replacement: passo 3, imagem 1 %32 Bissell PowerForce Compact Belt Replacement: passo 3, imagem 2 %32 Bissell PowerForce Compact Belt Replacement: passo 3, imagem 3 %32
    • Grab the rotating brush at both ends.
    • Lift the rotating brush straight out of the vacuum.
    • Remove the belt from the motor pulley.
  4. Bissell PowerForce Compact Belt Replacement: passo 4, imagem 1 %32 Bissell PowerForce Compact Belt Replacement: passo 4, imagem 2 %32
    • Clear the bottom of the vacuum from any debris that may be blocking air flow.
    • Clean the rotating brush from any wrapped string or hair. You can use scissors if needed.
  5. Bissell PowerForce Compact Belt Replacement: passo 5, imagem 1 %32 Bissell PowerForce Compact Belt Replacement: passo 5, imagem 2 %32 Bissell PowerForce Compact Belt Replacement: passo 5, imagem 3 %32
    • Check the new belt for any damage.
    • Place the belt on the rotating brush and then the motor pulley.
  6. Bissell PowerForce Compact Belt Replacement: passo 6, imagem 1 %32 Bissell PowerForce Compact Belt Replacement: passo 6, imagem 2 %32 Bissell PowerForce Compact Belt Replacement: passo 6, imagem 3 %32
    • Pull the rotating brush with the belt hooked.
    • Place the ends of the rotating brush into the slots.
    • Rotate the brush a few times to center the belt.
Conclusão
4 outras pessoas executaram este guia.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 41
Ao todo: 5,441
