Ir para o conteúdo principal
Bissell Pet Hair Eraser Vacuum Motor Replacement
O que você precisa
  1. Bissell Pet Hair Eraser Vacuum Motor Replacement, Dirt Cup: passo 1, imagem 1 %32 Bissell Pet Hair Eraser Vacuum Motor Replacement, Dirt Cup: passo 1, imagem 2 %32
    • Firmly grasp the handle and press the release button.
    • Gently pull the dirt cup down and away from the vacuum body.
  2. Bissell Pet Hair Eraser Vacuum Motor Replacement, Power Button: passo 2, imagem 1 %32 Bissell Pet Hair Eraser Vacuum Motor Replacement, Power Button: passo 2, imagem 2 %32
    • Remove the six 1.2 mm Philips #2 screws from the handle and base.
  3. Bissell Pet Hair Eraser Vacuum Motor Replacement: passo 3, imagem 1 %32 Bissell Pet Hair Eraser Vacuum Motor Replacement: passo 3, imagem 2 %32
    • Grasp each half of the body and gently pull apart.
    • The green handle, power button, charge light lens, and dirt cup release are not fastened in place.
    • Once the case is split apart these items may come dislodged.
  4. Bissell Pet Hair Eraser Vacuum Motor Replacement: passo 4, imagem 1 %32 Bissell Pet Hair Eraser Vacuum Motor Replacement: passo 4, imagem 2 %32 Bissell Pet Hair Eraser Vacuum Motor Replacement: passo 4, imagem 3 %32
    • The power button can be removed by gently lifting it off the circuitry.
  5. Bissell Pet Hair Eraser Vacuum Motor Replacement, Motherboard: passo 5, imagem 1 %32 Bissell Pet Hair Eraser Vacuum Motor Replacement, Motherboard: passo 5, imagem 2 %32
    • Remove the battery plastic hold down by lifting it off the tabs.
    • Remove the battery by lifting straight up.
    • Position the battery aside.
  6. Bissell Pet Hair Eraser Vacuum Motor Replacement: passo 6, imagem 1 %32 Bissell Pet Hair Eraser Vacuum Motor Replacement: passo 6, imagem 2 %32 Bissell Pet Hair Eraser Vacuum Motor Replacement: passo 6, imagem 3 %32
    • Grasp the charger port and remove it by lifting it straight out of the case.
    • Set the charger port next to the battery.
  7. Bissell Pet Hair Eraser Vacuum Motor Replacement: passo 7, imagem 1 %32 Bissell Pet Hair Eraser Vacuum Motor Replacement: passo 7, imagem 2 %32
    • Remove the power button and charge LED light by gently pulling straight out of the case.
    • The vacuum motor can be removed by pulling straight out of the case.
    • All internals are now removed.
    • Set the case halves aside.
  8. Bissell Pet Hair Eraser Vacuum Motor Replacement: passo 8, imagem 1 %32
    • Remove the two 1 mm Phillips #2 screws in the shown locations.
  9. Bissell Pet Hair Eraser Vacuum Motor Replacement: passo 9, imagem 1 %32 Bissell Pet Hair Eraser Vacuum Motor Replacement: passo 9, imagem 2 %32
    • Disconnect the power leads from the vacuum motor.
    • The red power lead goes on the terminal with the visible red dot.
  10. Bissell Pet Hair Eraser Vacuum Motor Replacement, Vacuum Motor: passo 10, imagem 1 %32 Bissell Pet Hair Eraser Vacuum Motor Replacement, Vacuum Motor: passo 10, imagem 2 %32
    • Grasp the vacuum motor and housing and pull them apart.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 34
Duração total: 1,201
