Ir para o conteúdo principal
Bissell Pet Hair Eraser Motorized Brush Belt Replacement
O que você precisa
  1. Bissell Pet Hair Eraser Motorized Brush Belt Replacement, Motorized Brush: passo 1, imagem 1 %32 Bissell Pet Hair Eraser Motorized Brush Belt Replacement, Motorized Brush: passo 1, imagem 2 %32
    • Turn power OFF.
    • Detach motorized brush from the vacuum.
  2. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: passo 2, imagem 1 %32 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: passo 2, imagem 2 %32
    • Use a spudger or a coin to turn the circular lock clockwise to unlock the brush roll.
    • Remove the lock cover.
  3. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: passo 3, imagem 1 %32
    • Lift brush out of the enclosure.
  4. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: passo 4, imagem 1 %32 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: passo 4, imagem 2 %32 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: passo 4, imagem 3 %32
    • Remove the four 13.0 mm Phillips #0 screws and remove the green cover.
  5. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: passo 5, imagem 1 %32
    • Take out the motor assembly.
  6. Bissell Pet Hair Eraser Motorized Brush Belt Replacement, Motorized Brush Belt: passo 6, imagem 1 %32
    • Take the belt off the gear by using a spudger.
  7. Bissell Pet Hair Eraser Motorized Brush Belt Replacement: passo 7, imagem 1 %32 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: passo 7, imagem 2 %32 Bissell Pet Hair Eraser Motorized Brush Belt Replacement: passo 7, imagem 3 %32
    • Grab the new belt and slide it on to the two gears.
    • Place the motor assembly back into the motorized brush enclosure.
Conclusão
To reassemble your device, follow the motorized brush disassembly instructions in reverse order.
Roman Dyagilev
Membro desde: 11/11/17
217 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S4-G4, Wilson Fall 2017 Membro de IUPUI, Team S4-G4, Wilson Fall 2017
IUPUI-WILSON-F17S4G4
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 422
