Ir para o conteúdo principal
Bissell OptiClean Cyclonic Vacuum Filter Replacements
O que você precisa
  1. Bissell OptiClean Cyclonic Vacuum Filter Replacements, Flex Hose with Handle: passo 1, imagem 1 %32 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Flex Hose with Handle: passo 1, imagem 2 %32
    • Grab hold of both the flex hose handle and the extension wand.
    • Pull straight out to detach the handle from the extension wand.
  2. Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 2, imagem 1 %32
    • Locate the lock clip on the other end of the flex hose.
  3. Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 3, imagem 1 %32 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 3, imagem 2 %32
    • Hold down the lock clip to unlock the flex hose from the vacuum.
    • Remove the flex hose from the vacuum.
  4. Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: passo 4, imagem 1 %32 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: passo 4, imagem 2 %32 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: passo 4, imagem 3 %32
    • After removing hose, place vacuum on back and unclip the top compartment.
    • Open the compartment.
    • Pull the dirt collection box out of the vacuum.
  5. Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 5, imagem 1 %32 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 5, imagem 2 %32 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 5, imagem 3 %32
    • Place dirt collection box to the side.
    • Locate the Pre-Motor Filter.
    • Pull the filter out by grabbing the pull tab on top.
  6. Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 6, imagem 1 %32 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 6, imagem 2 %32 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 6, imagem 3 %32
    • Turn vacuum around and locate the filter cover on the bottom.
    • Place fingers in the opening and pull off the filter cover.
    • Place fingers on each tab on the Post-Motor HEPA Media Filter and pull out.
  7. Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 7, imagem 1 %32 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 7, imagem 2 %32 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 7, imagem 3 %32
    • Take filter out to clean or replace.
    • To clean Dirt Collection Box, unlatch lid and take off.
  8. Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 8, imagem 1 %32 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 8, imagem 2 %32 Bissell OptiClean Cyclonic Vacuum Filter Replacements: passo 8, imagem 3 %32
    • Flip Dirt Collection Box over and locate the push tab.
    • Push the Dirt Cup HEPA Media Filter up to take it off.
    • Picture 3 Shows all the filters taken out of the vacuum.
Conclusão
Austin Marshall
Membro desde: 01/18/18
130 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S12-G1, Banghart Winter 2018 Membro de Cal Poly, Team S12-G1, Banghart Winter 2018
CPSU-BANGHART-W18S12G1
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 752
