Ir para o conteúdo principal
Bissell OptiClean Cyclonic Vacuum Flex Hose Replacement
  1. Bissell OptiClean Cyclonic Vacuum  Flex Hose Replacement, Flex Hose with Handle: passo 1, imagem 1 %32 Bissell OptiClean Cyclonic Vacuum  Flex Hose Replacement, Flex Hose with Handle: passo 1, imagem 2 %32
    • Grab hold of both the flex hose handle and the extension wand.
    • Pull straight out to detach the handle from the extension wand.
  2. Bissell OptiClean Cyclonic Vacuum  Flex Hose Replacement: passo 2, imagem 1 %32
    • Locate the lock clip on the other end of the flex hose.
  3. Bissell OptiClean Cyclonic Vacuum  Flex Hose Replacement: passo 3, imagem 1 %32 Bissell OptiClean Cyclonic Vacuum  Flex Hose Replacement: passo 3, imagem 2 %32
    • Hold down the lock clip to unlock the flex hose from the vacuum.
    • Remove the flex hose from the vacuum.
Conclusão
Devin Rojo-Cagadoc
Membro desde: 01/18/18
97 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S12-G1, Banghart Winter 2018 Membro de Cal Poly, Team S12-G1, Banghart Winter 2018
CPSU-BANGHART-W18S12G1
5 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 382
