Ir para o conteúdo principal
Bissell CrossWave Cordless Max 2554A Clean Water Filter Cap Replacement
  1. Bissell CrossWave Cordless Max 2554A Clean Water Filter Cap Replacement, Clean Water Filter Cap: passo 1, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Clean Water Filter Cap Replacement, Clean Water Filter Cap: passo 1, imagem 2 %32 Bissell CrossWave Cordless Max 2554A Clean Water Filter Cap Replacement, Clean Water Filter Cap: passo 1, imagem 3 %32
    • Remove the clean water tank from the main body by pulling down on the handle at the top of the tank.
  2. Bissell CrossWave Cordless Max 2554A Clean Water Filter Cap Replacement: passo 2, imagem 1 %32
    • Flip the tank 180 degrees so that the black cap is facing up.
    • If this step is not performed, water will spill out once the cap is removed.
  3. Bissell CrossWave Cordless Max 2554A Clean Water Filter Cap Replacement: passo 3, imagem 1 %32 Bissell CrossWave Cordless Max 2554A Clean Water Filter Cap Replacement: passo 3, imagem 2 %32 Bissell CrossWave Cordless Max 2554A Clean Water Filter Cap Replacement: passo 3, imagem 3 %32
    • Twist the cap clockwise until the cap is free from the rest of the tank.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 58
