Ir para o conteúdo principal
Bissell Bolt ION 2-in-1 Cordless Battery Replacement
O que você precisa
  1. Bissell Bolt ION 2-in-1 Cordless Battery Replacement, Battery: passo 1, imagem 1 %32 Bissell Bolt ION 2-in-1 Cordless Battery Replacement, Battery: passo 1, imagem 2 %32
    • Push the silver button to disconnect the dirt dish from the handheld vacuum.
  2. Bissell Bolt ION 2-in-1 Cordless Battery Replacement: passo 2, imagem 1 %32 Bissell Bolt ION 2-in-1 Cordless Battery Replacement: passo 2, imagem 2 %32
    • Remove the four 4 .4cm screws using your P0 screwdriver head and screwdriver.
    • Remove the Bissell sign to remove the two 4.4cm screws, using your P0 screwdriver head and screwdriver.
  3. Bissell Bolt ION 2-in-1 Cordless Battery Replacement: passo 3, imagem 1 %32 Bissell Bolt ION 2-in-1 Cordless Battery Replacement: passo 3, imagem 2 %32 Bissell Bolt ION 2-in-1 Cordless Battery Replacement: passo 3, imagem 3 %32
    • Using the metal spudger, insert and lift up to remove the frame from the body.
    • Move along the line and repeat on the other side.
  4. Bissell Bolt ION 2-in-1 Cordless Battery Replacement: passo 4, imagem 1 %32 Bissell Bolt ION 2-in-1 Cordless Battery Replacement: passo 4, imagem 2 %32
    • Remove the orange frame
    • Remove the 3 screws on the right side of the vacuum.
  5. Bissell Bolt ION 2-in-1 Cordless Battery Replacement: passo 5, imagem 1 %32 Bissell Bolt ION 2-in-1 Cordless Battery Replacement: passo 5, imagem 2 %32 Bissell Bolt ION 2-in-1 Cordless Battery Replacement: passo 5, imagem 3 %32
    • With metal spudger remove the metal clip on both sides.
    • Pull device apart using great force
Conclusão
13 outras pessoas executaram este guia.
Equipe
CSU Fullerton, Team S1-G3, Bruce Fall 2017 Membro de CSU Fullerton, Team S1-G3, Bruce Fall 2017
CSUF-BRUCE-F17S1G3
3 Membros
Autoria de 5 guias
24Comentários do guia
Do you have the specs for the replacement battery? Model number? Any suggested sources?
Don Abrams - Responder
There is no replacement battery. The vacuum does have a two year warranty. If you call Bissell, they will replace the vacuum.
Marietta Eastham - Responder
They will replace it with a refurbished one. In 6 months the same thing will happen and they don't warranty the replacement.
elarvick -
So why show how to take it apart if I can't replace the battery??
scott brumback - Responder
Dang, nice tutorial for a rather obscure dissection. Thank you.
nhgccc1 - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 78
Ao todo: 18,900
