Introdução
This guide will help you take apart the handheld vacuum using the most appropriate tools to replace the battery.
O que você precisa
13 outras pessoas executaram este guia.
23 comentários
Do you have the specs for the replacement battery? Model number? Any suggested sources?
There is no replacement battery. The vacuum does have a two year warranty. If you call Bissell, they will replace the vacuum.
They will replace it with a refurbished one. In 6 months the same thing will happen and they don't warranty the replacement.
elarvick -
So why show how to take it apart if I can't replace the battery??
