Introdução
What's going to happen in this replacement guide is the deconstruction of the Bionaire BAP 600 air purifier in order to de-solder the LED bulb from the LED Night Light.
O que você precisa
Grab the edge of the filter housing and pull the filter away from the rest of the device.
Next, once you see the interior of the air purifier there will be male ports with cables coming out of these ports as seen below. Thus, it is easy as taking the two wired male port (black and red) by pulling it towards you as seen below.
Note: There will be zip ties that are connecting the black and red wires together. Cut the zip ties.
Note: Pull the circuit board with the LED bulb underneath the air purifier gently in order to change out the LED bulb.
Now, use a soldering kit in order to de-solder the solder that’s on the circuit board with the LED light as seen below. Hence, once you de-solder the solder from the LED light’s wires you can move on to the next step.
