Introdução
This is a replacement guide that will use previous replacement guides in order to achieve the end goal of replacing the exhaust vent.
O que você precisa
Rotate the base counterclockwise, supporting the top with your opposite hand.
Grab the edge of the filter housing and pull the filter away from the rest of the device.
Use a flathead tool to place it in between the the exhaust vent and the inner side of the outer shell.
Uma outra pessoa concluiu este guia.
