Ir para o conteúdo principal
Bionaire BAP 600 Air Filter Replacement
  1. Bionaire BAP 600 Air Filter Replacement, Base/Intake: passo 1, imagem 1 %32
    • Rotate base counterclockwise, supporting top with opposite hand.
  2. Bionaire BAP 600 Air Filter Replacement: passo 2, imagem 1 %32
    • Pull base away from housing exposing air filter.
  3. Bionaire BAP 600 Air Filter Replacement, Air Filter: passo 3, imagem 1 %32
    • Grab the edge of the filter housing and pull the filter away from the rest of the device.
  4. Bionaire BAP 600 Air Filter Replacement: passo 4, imagem 1 %32
    • Gently pull apart each fold of the filter to check for abrasions or other anomalies. Clean with a dust rag if necessary.
Conclusão
Uma outra pessoa concluiu este guia.
Nick Miller
Membro desde: 10/26/16
167 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 4-4, Baechle Fall 2016 Membro de IUPUI, Team 4-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S4G4
Membros da 5
Autoria de 7 guias
3 comentários
Bonjour.merci pour le tutoriel,mais où trouver un filtre…
Frederic Battele - Responder
Where such a filter can be bought? I was in Italy when I order mine from Amazon (UK) but can't find the filter to replace, I damaged mine.
Any idea?
Nuno Filipe - Responder
I been searching for 3 years now. They don't make them. You have to buy a new one. I went to Honeywell and not had a problem.
Blake PS -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 23
Duração total: 2,441
