Ir para o conteúdo principal
Bike Chain Installation
O que você precisa
  1. Bike Chain Installation, Bike Chain Installation: passo 1, imagem 1 %32 Bike Chain Installation, Bike Chain Installation: passo 1, imagem 2 %32
    • Rout the chain around the front chain rings and rear derailleur.
    • Pull the ends of the chain together.
  2. Bike Chain Installation: passo 2, imagem 1 %32 Bike Chain Installation: passo 2, imagem 2 %32
    • Use the chain cutter tool to press the chain pin back through the chain link. If it is difficult to push it back in, the links are not aligned properly. Realign and try again if this is the case.
    • Caution: Reusing pins in chains can cause the chain to fail. This is because the pins are press fit into link. Using a new pin when assembling a chain is recommend for long term use.
Linha de Chegada
3 outras pessoas executaram este guia.
aaron thielk
Membro desde: 10/10/10
1.882 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 5-13, Maness Fall 2010 Membro de Cal Poly, Team 5-13, Maness Fall 2010
CPSU-MANESS-F10S5G13
Membros da 4
Autoria de 17 guias
2 comentários
what do you do if the Chain keeps Falling off when your Riding the Bike an the Chain still rubs against the tire .
Anthony - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 31
Duração total: 15,963
