Pular para o conteúdo principal
Introdução
This guide will show you how to remove an inner tube from a bicycle tire. The process is the same for both front and rear wheels, even though this guide demonstrates the process on the rear wheel. While some components on your bicycle may be different than those shown here, the process will be the same.
Ferramentas
Peças
Nenhum componente especificado.
  1. Flip the quick release lever on the wheel. Flip the quick release lever on the wheel.
    • Flip the quick release lever on the wheel.
  2. Squeeze the brake arms together and lift the brake cable from the caliper arms.
    • Squeeze the brake arms together and lift the brake cable from the caliper arms.
  3. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  4. Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
    • Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
  5. Press the valve core while applying pressure to the tire to deflate the tire.
    • Press the valve core while applying pressure to the tire to deflate the tire.
  6. Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel. Slide the lever around the circumference of the wheel to completely remove the tire.
    • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
    • Slide the lever around the circumference of the wheel to completely remove the tire.
    • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
  7. Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
    • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
Conclusão
Re-insert the tube into the tire, and align the tube with the hole in the rim. Using the plastic tire levers, re-seat the tire on the rim. When inflating the tire, proceed slowly, ensuring that the bead is seated properly on the rim.
4 outras pessoas concluíram este guia.
Brett Hartt
Membro desde: 12-04-2010
111.177 reputação
138 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
104 Membros
8.415 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 55
Todo: 5,742
