Ir para o conteúdo principal
Bicycle Handlebar Tape Replacement
O que você precisa
  1. Bicycle Handlebar Tape Replacement, Handlebar Tape: passo 1, imagem 1 %32 Bicycle Handlebar Tape Replacement, Handlebar Tape: passo 1, imagem 2 %32 Bicycle Handlebar Tape Replacement, Handlebar Tape: passo 1, imagem 3 %32
    • Undo the brake cables holding the brake calipers under tension.
    • Depress the brake/shift levers (brifters) and insert a 5mm Allen key into the internal bolt. This bolt secures the brifters to the handlebar.
    • With the 5mm Allen key, loosen and temporarily remove brifters.
  2. Bicycle Handlebar Tape Replacement: passo 2, imagem 1 %32 Bicycle Handlebar Tape Replacement: passo 2, imagem 2 %32 Bicycle Handlebar Tape Replacement: passo 2, imagem 3 %32
    • Remove the old tape and discard.
    • Pour some rubbing alcohol on the rag and clean any old adhesive residue off the handlebar.
  3. Bicycle Handlebar Tape Replacement: passo 3, imagem 1 %32 Bicycle Handlebar Tape Replacement: passo 3, imagem 2 %32 Bicycle Handlebar Tape Replacement: passo 3, imagem 3 %32
    • Starting on the right side of the handlebar, wrap the new tape around the end in a clockwise direction moving inward.
    • Be sure to wrap the tape tight, but don't pull so hard that it rips!
    • Using the scissors, cut the tape at an angle towards the outside of the bar.
    • Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured here)
  4. Bicycle Handlebar Tape Replacement: passo 4, imagem 1 %32 Bicycle Handlebar Tape Replacement: passo 4, imagem 2 %32 Bicycle Handlebar Tape Replacement: passo 4, imagem 3 %32
    • On the left side of the handlebar, wrap the tape around the end in a counter-clockwise direction moving inward.
    • Wrap tight, but don't rip!
    • Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured).
  5. Bicycle Handlebar Tape Replacement: passo 5, imagem 1 %32 Bicycle Handlebar Tape Replacement: passo 5, imagem 2 %32
    • Using the 5mm Allen key, reattach and tighten the brifter levers onto the handlebar.
  6. Bicycle Handlebar Tape Replacement: passo 6, imagem 1 %32 Bicycle Handlebar Tape Replacement: passo 6, imagem 2 %32
    • Reattach the brake cables to the brifters and brake calipers
    • Depress the brake levers a couple of times to test and confirm that the cables were reinstalled properly before riding.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Jordan Byrnes
Membro desde: 05/05/17
132 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S1-G70, Coad Spring 2017 Membro de UC Davis, Team S1-G70, Coad Spring 2017
UCD-COAD-S17S1G70
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 583
