Introdução
The handlebars are one of the main points of contact between a cyclist and his or her bicycle and serve as the primary means of controlling the bicycle, housing the controls for such essential functions as steering and braking. A cyclist's ability to comfortably operate these mechanisms for extended periods of time is of the utmost importance. Old, worn out handlebar tape may pose a danger to cyclists because, with no barrier between the bicycle's controls and the harsh elements, brake cables may become damaged; also, the cyclist may be put at a greater risk of developing blisters. With the brakes inoperable and the cyclist's palms blistered, the chances of the cyclist losing control of the bicycle and getting into an accident skyrocket. New, properly wrapped bar tape both provides a cushion between the cyclist's hands and the rough surface of the handlebars and shields the brake cables from the elements, decreasing the chances of accidents and ensuring a more comfortable and safe ride.
O que você precisa
Have someone hold the bicycle and handlebars steady throughout the fix.
Roll back the brake hood cover on one of the handlebars.
Pop out the bar plug at the end of the handlebar.
Peel off the old handlebar tape entirely.
After removing the old handlebar tape, the old electrical tape securing the brake cables will be revealed.
Remove the old electrical tape if it is not satisfactorily securing the brake cables.
Apply new electrical tape to secure the brake cables.
Peel off a few feet of the adhesive backing on the roll of new bar tape.
Affix the center of the end of the tape to the edge of the drop bar so that half of the width of the tape hangs over the end of the bar.
Begin to snugly wrap the tape up the handlebar, pulling the tape up and over the handlebar toward the bicycle.
Repeat all steps to replace the old handlebar tape on the other handlebar.
