Ir para o conteúdo principal
Besta Super 5000 Motherboard Replacement
O que você precisa
  1. Besta Super 5000 Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn the device over so that the barcode is facing upwards.
  2. Besta Super 5000 Motherboard Replacement: passo 2, imagem 1 %32 Besta Super 5000 Motherboard Replacement: passo 2, imagem 2 %32
    • Place your fingers on the battery cover arrow and pull the cover down and off the device.
  3. Besta Super 5000 Motherboard Replacement: passo 3, imagem 1 %32
    • Pull upwards on the battery tab to remove the battery from the device.
  4. Besta Super 5000 Motherboard Replacement, Back Cover: passo 4, imagem 1 %32
    • Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
  5. Besta Super 5000 Motherboard Replacement: passo 5, imagem 1 %32
    • Remove the two screws behind the battery using a Phillips #0 screwdriver.
  6. Besta Super 5000 Motherboard Replacement: passo 6, imagem 1 %32 Besta Super 5000 Motherboard Replacement: passo 6, imagem 2 %32
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the device with screws still in it because you may damage it.
    • Gently pry off the backing using an opening tool.
  7. Besta Super 5000 Motherboard Replacement, Motherboard: passo 7, imagem 1 %32
    • Remove the three silver screws from the black round battery using a Phillips #0 screwdriver.
  8. Besta Super 5000 Motherboard Replacement: passo 8, imagem 1 %32
    • Remove the five small screws from the motherboard using a Phillips #0 screwdriver.
  9. Besta Super 5000 Motherboard Replacement: passo 9, imagem 1 %32 Besta Super 5000 Motherboard Replacement: passo 9, imagem 2 %32 Besta Super 5000 Motherboard Replacement: passo 9, imagem 3 %32
    • Using a pair of tweezers, pinch the center of the yellow ribbon located in the corner of the device.
    • Potential for device damage: Do not yank or remove the ribbon from the device.
    • Carefully pull the hidden piece of yellow ribbon out from underneath the motherboard.
  10. Besta Super 5000 Motherboard Replacement: passo 10, imagem 1 %32 Besta Super 5000 Motherboard Replacement: passo 10, imagem 2 %32
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the motherboard with screws still in it because you may damage it.
    • Carefully pry off the motherboard with an opening tool.
  11. Besta Super 5000 Motherboard Replacement: passo 11, imagem 1 %32
    • Take the motherboard out of the body frame.
  12. Besta Super 5000 Motherboard Replacement: passo 12, imagem 1 %32 Besta Super 5000 Motherboard Replacement: passo 12, imagem 2 %32
    • Lift the black keyboard mat off of the motherboard.
    • Replace the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Jessie
Membro desde: 09/30/14
370 Reputação
Autoria de 3 guias
Equipe
Ohio State, Team 1-5, Buehl Fall 2014 Membro de Ohio State, Team 1-5, Buehl Fall 2014
OSU-BUEHL-F14S1G5
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 14
Duração total: 371
