Ir para o conteúdo principal
Bem Wireless HL2739B Speaker Battery Replacement
O que você precisa
  1. Bem Wireless HL2739B Speaker Battery Replacement, Speaker Battery: passo 1, imagem 1 %32
    • Peel the rubber cover back from the corner of the speaker to reveal the screw.
    • Repeat for the three remaining corners.
  2. Bem Wireless HL2739B Speaker Battery Replacement: passo 2, imagem 1 %32 Bem Wireless HL2739B Speaker Battery Replacement: passo 2, imagem 2 %32 Bem Wireless HL2739B Speaker Battery Replacement: passo 2, imagem 3 %32
    • Use the J1 bit attached to the screwdriver to remove the four 10mm screws from the bottom of the speaker.
  3. Bem Wireless HL2739B Speaker Battery Replacement: passo 3, imagem 1 %32
    • Lift the bottom cover away from the rest of the speaker.
    • There are wires connecting the battery and cover to the rest of the speaker. Be careful when removing the base cover.
    • Using the tweezers, pull the wires from the speaker's internal chip.
    • Be careful not to damage the chip when you remove the wires.
    • It will likely require soldering to reassemble the speaker after this step.
  4. Bem Wireless HL2739B Speaker Battery Replacement: passo 4, imagem 1 %32
    • Using a plastic opening tool, gently pry the battery from the metal base.
  5. Bem Wireless HL2739B Speaker Battery Replacement: passo 5, imagem 1 %32
    • Using tweezers, pull the wires from the metal base connection.
Conclusão
3 outras pessoas executaram este guia.
John Donovan
Membro desde: 02/28/17
137 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S2-G4, Nance Spring 2017 Membro de USF Tampa, Team S2-G4, Nance Spring 2017
USFT-NANCE-S17S2G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 2,429
