Ir para o conteúdo principal
Bella 4-Slice Toaster Oven Temperature Dial Replacement
O que você precisa
  1. Bella 4-Slice Toaster Oven Temperature Dial Replacement, Outer Shell: passo 1, imagem 1 %32
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Temperature Dial Replacement: passo 2, imagem 1 %32
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Temperature Dial Replacement: passo 3, imagem 1 %32
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Temperature Dial Replacement: passo 4, imagem 1 %32
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Temperature Dial Replacement: passo 5, imagem 1 %32
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Temperature Dial Replacement: passo 6, imagem 1 %32
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Temperature Dial Replacement: passo 7, imagem 1 %32
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Temperature Dial Replacement: passo 8, imagem 1 %32
    • Lift the black outer cover off of the toaster
  9. Bella 4-Slice Toaster Oven Temperature Dial Replacement, Temperature Dial: passo 9, imagem 1 %32
    • Using a plastic spudger, gently pry the black plastic temperature dial away from the face of the toaster.
  10. Bella 4-Slice Toaster Oven Temperature Dial Replacement: passo 10, imagem 1 %32
    • Remove two 5.91 mm #2 Phillips screws which secure the inner component to the toaster.
  11. Bella 4-Slice Toaster Oven Temperature Dial Replacement: passo 11, imagem 1 %32
    • Inside the device, unplug the red wire connecting the black plastic part of the dial to the heating element.
  12. Bella 4-Slice Toaster Oven Temperature Dial Replacement: passo 12, imagem 1 %32
    • Now unplug the other red wire from the black plastic part of the dial.
  13. Bella 4-Slice Toaster Oven Temperature Dial Replacement: passo 13, imagem 1 %32
    • Unplug the two white wires from the metal part of the dial.
  14. Bella 4-Slice Toaster Oven Temperature Dial Replacement: passo 14, imagem 1 %32
    • Remove the dial from device interior.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 405
