Ir para o conteúdo principal
Bella 4-Slice Toaster Oven Outer Shell Replacement
O que você precisa
  1. Bella 4-Slice Toaster Oven Outer Shell Replacement, Outer Shell: passo 1, imagem 1 %32
    • Remove five 11.6 mm Phillips #2 screws from the rear of the device.
  2. Bella 4-Slice Toaster Oven Outer Shell Replacement: passo 2, imagem 1 %32
    • Open the front glass door of the toaster oven.
  3. Bella 4-Slice Toaster Oven Outer Shell Replacement: passo 3, imagem 1 %32
    • Locate retaining screw on the upper-middle portion of the door frame.
  4. Bella 4-Slice Toaster Oven Outer Shell Replacement: passo 4, imagem 1 %32
    • Remove one 21.9 mm Phillips #2 retaining screw from upper-middle portion of door frame.
  5. Bella 4-Slice Toaster Oven Outer Shell Replacement: passo 5, imagem 1 %32
    • Flip toaster onto back panel with feet facing forward.
  6. Bella 4-Slice Toaster Oven Outer Shell Replacement: passo 6, imagem 1 %32
    • Use spudger to pry the grey rubber inserts from the black plastic feet.
  7. Bella 4-Slice Toaster Oven Outer Shell Replacement: passo 7, imagem 1 %32
    • Remove four 13.7mm Phillips #2 screws from black plastic feet to separate the cover from the device.
  8. Bella 4-Slice Toaster Oven Outer Shell Replacement: passo 8, imagem 1 %32
    • Lift the black outer cover off of the toaster
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 385
