Ir para o conteúdo principal
Bell and Howell DNV16HDZ LED Replacement
O que você precisa
  1. Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: passo 1, imagem 1 %32 Bell and Howell DNV16HDZ LED Replacement, Lens Assembly: passo 1, imagem 2 %32
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ LED Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ LED Replacement: passo 3, imagem 1 %32
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ LED Replacement, LED: passo 4, imagem 1 %32
    • Take out the two 20 mm Phillips #0 screws that attach it to the shutter.
  5. Bell and Howell DNV16HDZ LED Replacement: passo 5, imagem 1 %32 Bell and Howell DNV16HDZ LED Replacement: passo 5, imagem 2 %32 Bell and Howell DNV16HDZ LED Replacement: passo 5, imagem 3 %32
    • The two 30 mm Phillips #0 screws left can be removed to gain access to the circuit board along with the LED.
    • From here we can pop out the LED using the wedge or your fingers if you can manage it.
Conclusão
Donald Desrosier
Membro desde: 03/11/16
101 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 8-4, Botvin Spring 2016 Membro de UMass Dartmouth, Team 8-4, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G4
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 317
