Ir para o conteúdo principal
Bell and Howell DNV16HDZ Hand Strap Replacement
O que você precisa
  1. Bell and Howell DNV16HDZ Hand Strap Replacement, Lens Assembly: passo 1, imagem 1 %32 Bell and Howell DNV16HDZ Hand Strap Replacement, Lens Assembly: passo 1, imagem 2 %32
    • Remove the five 30mm Phillips #0 screws on the bottom of the camera.
  2. Bell and Howell DNV16HDZ Hand Strap Replacement: passo 2, imagem 1 %32
    • Use a plastic opening tool to disconnect the internal hinges that snaps the camera into place.
    • Using a plastic opening tool is important since a metal one will scratch or damage the thin plastic hinges that hold the camera together.
  3. Bell and Howell DNV16HDZ Hand Strap Replacement: passo 3, imagem 1 %32
    • It will still be connected by a plastic film. This can also be disconnected by pulling up the white part where it connects to the light circuit board.
  4. Bell and Howell DNV16HDZ Hand Strap Replacement, Hand Strap: passo 4, imagem 1 %32 Bell and Howell DNV16HDZ Hand Strap Replacement, Hand Strap: passo 4, imagem 2 %32
    • Pull the side with the hand strap upwards to disconnect it from the camcorder.
    • Unscrew the four 40 mm Phillips #0 screws.
    • Add the new hand strap now.
Conclusão
Jerry Hadjah
Membro desde: 03/04/16
525 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 8-4, Botvin Spring 2016 Membro de UMass Dartmouth, Team 8-4, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G4
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 207
