Introdução
When you know your phone connection with the camera is good, but no sound is going through. The speaker could have gone out and needs to be replaced.
O que você precisa
Use a wrench to loosen up the stand from the back in order to hold the NetCam more comfortably.
Carefully use your fingers to gently pull out the white attachment from the tan colored part.
Use a Phillips #0 screwdriver to take out the two 1.2 mm screws on the board.
Quase terminado!
Conclusão
