Ir para o conteúdo principal
Belkin F5L114 Battery Replacement
O que você precisa
  1. Belkin F5L114 Battery Replacement, Battery: passo 1, imagem 1 %32 Belkin F5L114 Battery Replacement, Battery: passo 1, imagem 2 %32 Belkin F5L114 Battery Replacement, Battery: passo 1, imagem 3 %32
    • Switch the power button that is located at the bottom left of the keyboard to Off.
  2. Belkin F5L114 Battery Replacement: passo 2, imagem 1 %32 Belkin F5L114 Battery Replacement: passo 2, imagem 2 %32
    • Flip the keyboard over.
  3. Belkin F5L114 Battery Replacement: passo 3, imagem 1 %32 Belkin F5L114 Battery Replacement: passo 3, imagem 2 %32 Belkin F5L114 Battery Replacement: passo 3, imagem 3 %32
    • Pull back gently on the left side of the bottom-left rubber foot enough to expose the small screw.
  4. Belkin F5L114 Battery Replacement: passo 4, imagem 1 %32
    • Use a Phillips #0 screwdriver to unscrew the screw.
    • The screw may not come fully out of the device.
  5. Belkin F5L114 Battery Replacement: passo 5, imagem 1 %32
    • Pull back gently on the bottom left corner of the middle rubber foot enough to expose the small screw.
  6. Belkin F5L114 Battery Replacement: passo 6, imagem 1 %32
  7. Belkin F5L114 Battery Replacement: passo 7, imagem 1 %32 Belkin F5L114 Battery Replacement: passo 7, imagem 2 %32
    • Pull back gently on the right side of the bottom-right rubber enough to expose the small screw.
  8. Belkin F5L114 Battery Replacement: passo 8, imagem 1 %32
  9. Belkin F5L114 Battery Replacement: passo 9, imagem 1 %32 Belkin F5L114 Battery Replacement: passo 9, imagem 2 %32
    • Insert the spudger into the space next to the right screw area.
    • Gently pry open the battery case.
  10. Belkin F5L114 Battery Replacement: passo 10, imagem 1 %32 Belkin F5L114 Battery Replacement: passo 10, imagem 2 %32 Belkin F5L114 Battery Replacement: passo 10, imagem 3 %32
    • Gently pry the battery cover off.
  11. Belkin F5L114 Battery Replacement: passo 11, imagem 1 %32 Belkin F5L114 Battery Replacement: passo 11, imagem 2 %32
    • Remove the battery cover.
    • Locate the battery.
  12. Belkin F5L114 Battery Replacement: passo 12, imagem 1 %32 Belkin F5L114 Battery Replacement: passo 12, imagem 2 %32
    • Lift the battery up using the spudger.
    • The battery is taped down.
  13. Belkin F5L114 Battery Replacement: passo 13, imagem 1 %32 Belkin F5L114 Battery Replacement: passo 13, imagem 2 %32 Belkin F5L114 Battery Replacement: passo 13, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently unplug the battery from the motherboard using the tweezers.
    • Remove the battery.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Hi, I would like buy another battery for my keyboard. May you help me please?
Rundy Henry - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 49
Duração total: 867
