Ir para o conteúdo principal
Beiens Cartoon RC Race Car Car Battery Replacement
O que você precisa
  1. Beiens Cartoon RC Race Car Car Battery Replacement, Car Battery: passo 1, imagem 1 %32
    • On the bottom of the car, unscrew the 6.2 mm screw that houses the batteries using a Philips 00 precision screwdriver.
  2. Beiens Cartoon RC Race Car Car Battery Replacement: passo 2, imagem 1 %32
    • Pull up the tab to reveal the battery compartment.
  3. Beiens Cartoon RC Race Car Car Battery Replacement: passo 3, imagem 1 %32
    • Insert AA batteries into the 3 spaces with the flat end of the battery facing the metal spring.
    • Be sure to insert the batteries with the positive and negative ends facing the right direction. The flat negative end of the battery should be in contact with the spring in the remote control car.
Conclusão
This guide was made to work for the Beiens Cartoon RC Race Car with AA batteries, but it should also work with other similar modeled RC cars that take AA batteries.
Amber Ashley
Membro desde: 10/01/15
329 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 1-6, Leahy Fall 2015 Membro de USF Tampa, Team 1-6, Leahy Fall 2015
USFT-LEAHY-F15S1G6
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 584
