O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
unscrew two Phillips screws on each side of the BCD3000
If the screws sit too tight, you can use the extension for better torque
Lift the upper control part.
Disconnect the cables by walking them out of their sockets.
Disconnect the two cables from the lower section to the connector board.
Slide the lower section to the front.
Now you can lift it and take it aside.
Disconnect the separate boards.
Now you can take the modules out by unscrewing them from the case.
The jog wheels on the front panel can be taken off by using a spudger and levering them out.
Same goes for the knobs on the top section of the front panel.
3 outras pessoas concluíram este guia.
2 comentários
great stuff, with better quality pictures would be better
