Ir para o conteúdo principal
Bed boards Replacement
O que você precisa
  1. Bed boards Replacement, Bed Boards: passo 1, imagem 1 %32 Bed boards Replacement, Bed Boards: passo 1, imagem 2 %32
    • Remove the matress from the bed.
  2. Bed boards Replacement: passo 2, imagem 1 %32
    • Remove the box spring from the bed.
  3. Bed boards Replacement: passo 3, imagem 1 %32
    • Remove the old boards using the Phillips #1 screwdriver.
  4. Bed boards Replacement: passo 4, imagem 1 %32
    • Using your measure tape, measure the old boards and write down the measurements.
  5. Bed boards Replacement: passo 5, imagem 1 %32
    • Find some wooden boards with 2x2 measures (width) and with the length you already measured.
  6. Bed boards Replacement: passo 6, imagem 1 %32 Bed boards Replacement: passo 6, imagem 2 %32
    • Screw in the replacement boards.
  7. Bed boards Replacement: passo 7, imagem 1 %32 Bed boards Replacement: passo 7, imagem 2 %32 Bed boards Replacement: passo 7, imagem 3 %32
    • Put your box spring and mattress back and you are done.
Conclusão
To assemble your bed boards just follow the steps provided in the order given and your bed boards will be ready to go.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 128
Ao todo: 1,948
