Introdução
This guide describes how to remove broken or damaged buttons for the BEBONCOOL Wireless Switch Pro Controller.
The Beboncool Gamepad has many buttons that all operate in the same manner. A broken or malfunctioning button is rather easy to identify when not getting the correct response or no response at all when pressing the button in a game. Replacing the button will likely fix the issue.
O que você precisa
Use a Phillips #0 screwdriver to remove the seven 5 mm screws from the back of the controller.
Ferramenta utilizada neste passo:Tweezers$4.99
To remove the alphabetic buttons, remove the translucent silicone cover.
Use tweezers or your fingers to remove the buttons.
