Ir para o conteúdo principal
Beboncool Gamepad for Nintendo Switch Charging Port Replacement
O que você precisa
  1. Beboncool Gamepad for Nintendo Switch Charging Port Replacement, Charging Port: passo 1, imagem 1 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement, Charging Port: passo 1, imagem 2 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement, Charging Port: passo 1, imagem 3 %32
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
  2. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 2, imagem 1 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 2, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
  3. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 3, imagem 1 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 3, imagem 2 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 3, imagem 3 %32
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
  4. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 4, imagem 1 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 4, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
  5. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 5, imagem 1 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 5, imagem 2 %32
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
  6. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 6, imagem 1 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 6, imagem 2 %32
    • Gently pull the battery from the circuit board, leaving it connected to the board with its lead wires.
  7. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 7, imagem 1 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 7, imagem 2 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 7, imagem 3 %32
    • Remove the charging port from the edge of the motherboard by desoldering each of its four solder points and lifting the port from the board.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 36
Ao todo: 1,048
