Ir para o conteúdo principal
Beboncool Gamepad for Nintendo Switch Charging Port Replacement
O que você precisa
  1. Beboncool Gamepad for Nintendo Switch Charging Port Replacement, Charging Port: passo 1, imagem 1 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement, Charging Port: passo 1, imagem 2 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement, Charging Port: passo 1, imagem 3 %32
    • Use the plastic opening tool to remove the blue plastic grips from the sides of the controller.
  2. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 2, imagem 1 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 2, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the seven 5mm screws from the back of the controller.
  3. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 3, imagem 1 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 3, imagem 2 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 3, imagem 3 %32
    • Gently separate the two halves of the controller.
    • As the two covers come apart the L1 and R1 button, will fall free from the controller. Be sure not to lose them if they should pop out and fall.
    • Be sure to slide the small circuit boards out of the covers to be able to separate the two halves
  4. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 4, imagem 1 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 4, imagem 2 %32
    • Use the Phillips #0 screwdriver to remove the two 3.5mm screws holding the circuit board in place.
  5. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 5, imagem 1 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 5, imagem 2 %32
    • Lift the motherboard from the back case with the vibration motors and button boards attached.
  6. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 6, imagem 1 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 6, imagem 2 %32
    • Gently pull the battery from the circuit board, leaving it connected to the board with its lead wires.
  7. Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 7, imagem 1 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 7, imagem 2 %32 Beboncool Gamepad for Nintendo Switch Charging Port Replacement: passo 7, imagem 3 %32
    • Remove the charging port from the edge of the motherboard by desoldering each of its four solder points and lifting the port from the board.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 663
