Introdução
Removing the ear cushion is an important first step to accessing the speaker housing. Unless you are only replacing the headband, You MUST remove the ear cushions to access the other components.
O que você precisa
Pinch the ear cushion between your thumb and forefinger.
Carefully pull the cushion directly away from the earpiece.
Repeat for the other ear cushion.
Use the plastic opening tool to remove the black ring from the speaker. This will allow you to access the screws on the metal ring.
Congratulations, you now have access to the rest of the speaker!
The black lip is located on the back side of the ear cushion.
I bought the parts two (2) ear cushions and a head band replacement on eBay for about $10 USD
the process described here works well if the ear pad is old and you do not mind destroying the old one to gain access - however you will destroy the ear cushion pad assembly to separate it from the headphones - so be prepared to buy replacement cushion assemblies - when you disassemble you cannot re-install the original cushions
the disassembly process tears the plastic cover that goes around the ear cushion plastic ring
15 outras pessoas executaram este guia.
4 comentários
De nada me sirve saber cómo colocarlos si no sé donde conseguirlos... Ese debería ser el paso 1 del instructivo...
Hi - do you know where i can buy the replacement ear cushions for these particular headphones?
Yes! We do offer these here:
Cooper -
i have torn my cuson inside part that helps to hold the out soft part. and i lost it how to do it
imbd Indian medicine bd - Responder
