Ir para o conteúdo principal
Beats Studio 2.0 Wireless Left Interior Side Panel Replacement
O que você precisa
  1. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement, Left Interior Side Panel: passo 1, imagem 1 %32
    • Use metal spudger to pry away ear cushion.
  2. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 2, imagem 1 %32
    • Remove ear cushion from headphones (attached by adhesive).
  3. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 3, imagem 1 %32
    • Remove two screws from the metal hinge using a Phillips head screwdriver to allow more motion from the speaker housing and more accessibility.
  4. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 4, imagem 1 %32
    • Remove five screws using a Phillips head screwdriver from speaker housing.
  5. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 5, imagem 1 %32
    • Pull speaker away to access second secondary housing.
    • Be careful not to stress wires and break solder points.
  6. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 6, imagem 1 %32 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 6, imagem 2 %32
    • Raise center cover.
    • Remove screw from center of housing.
  7. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 7, imagem 1 %32
    • Pull secondary housing away gently being careful not to damage the wires.
  8. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 8, imagem 1 %32
    • Remove four screws using a Phillips head screwdriver to remove the third housing.
  9. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 9, imagem 1 %32 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 9, imagem 2 %32 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 9, imagem 3 %32
    • Disconnect wires gently.
    • Be gentle with the wires ensuring to pull them through with care to eliminate possible shortages.
  10. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 10, imagem 1 %32 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 10, imagem 2 %32 Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 10, imagem 3 %32
    • Pass wire through new housing and reconnect wires.
  11. Beats Studio 2.0 Wireless  Left Interior Side Panel Replacement: passo 11, imagem 1 %32
    • Snap housing into place.
    how did you disconnect the red & black wires?
    I was able to disconnect other two rather easily but cannot seem disconnect 3rd one.
    thanks!
    hong - Responder
Conclusão
Uma outra pessoa concluiu este guia.
Antares Cam
Membro desde: 02/27/18
235 Reputação
Autoria de 1 guia
Equipe
colby and cameron Membro de colby and cameron
Community
Membros da 2
1 Guia de autoria
2 comentários
Thank you for your tutorial!
Jonathan Concepcion - Responder
appreciate it, fixed both side panels on my beats
mridha31 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 34
Duração total: 5,624
