Ir para o conteúdo principal
Beats Studio 2 Wireless Headband Replacement
O que você precisa
  1. Beats Studio 2 Wireless Headband Replacement, Headband: passo 1, imagem 1 %32 Beats Studio 2 Wireless Headband Replacement, Headband: passo 1, imagem 2 %32
    • Slide the headband down on one side to reveal the two screws under the silver "Studio" label.
    • Use a T5 screwdriver to remove the two screws securing the headband pieces.
    • Slide the headband down on the other side to reveal the two screws beneath the "Wireless" label.
  2. Beats Studio 2 Wireless Headband Replacement: passo 2, imagem 1 %32 Beats Studio 2 Wireless Headband Replacement: passo 2, imagem 2 %32
    • Slide the headband away from the silver "Studio" and "Wireless" silver bands.
    • Peel the rubber interior layer off of the headband to remove it.
    • Save the rubber layer of the headband for your replacement.
  3. Beats Studio 2 Wireless Headband Replacement: passo 3, imagem 1 %32
    • Use a nylon spudger to undo the tabs connecting the foam interior of the headband to the outer shell.
    • Remove the foam interior part of the headphone.
  4. Beats Studio 2 Wireless Headband Replacement: passo 4, imagem 1 %32 Beats Studio 2 Wireless Headband Replacement: passo 4, imagem 2 %32
    • The exterior shell of the headband should come off easily at this point or just detach automatically.
Conclusão
3 outras pessoas executaram este guia.
Mike Rosiello
Membro desde: 03/20/23
325 Reputação
Autoria de 2 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 19
Últimos 30 dias: 80
Ao todo: 1,883
