Ir para o conteúdo principal
Beats Solo 3 Earpads Replacement
O que você precisa
  1. Beats Solo 3 Earpads Replacement, Earpads: passo 1, imagem 1 %32 Beats Solo 3 Earpads Replacement, Earpads: passo 1, imagem 2 %32
    • Use a halberd spudger to create a gap between the earpads and the main body.
  2. Beats Solo 3 Earpads Replacement: passo 2, imagem 1 %32 Beats Solo 3 Earpads Replacement: passo 2, imagem 2 %32
    • Peel away the earpads from the headphone earcups.
    • Be gentle when separating the earpads from the main body. Too much force may damage the main body.
  3. Beats Solo 3 Earpads Replacement: passo 3, imagem 1 %32 Beats Solo 3 Earpads Replacement: passo 3, imagem 2 %32 Beats Solo 3 Earpads Replacement: passo 3, imagem 3 %32
    • Remove the black tape with your hands.
    • Be sure to clean the black tape thoroughly, as uncleaned tape can hinder the adhesive of the new pads.
  4. Beats Solo 3 Earpads Replacement: passo 4, imagem 1 %32
    • Spread a thin layer of glue around the grey perimeter of the new earpads.
    • Don’t put too much glue on or it will spill out and make the earpads dirty.
  5. Beats Solo 3 Earpads Replacement: passo 5, imagem 1 %32 Beats Solo 3 Earpads Replacement: passo 5, imagem 2 %32
    • Install the new pads.
    • Be sure to position the earpads properly on the earcups before adhering.
    • The pads may take a minute to stay together, be patient.
Conclusão
8 outras pessoas executaram este guia.
Xin
Membro desde: 09/19/21
315 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 11
Últimos 7 dias: 81
Últimos 30 dias: 463
Duração total: 14,027
