Ir para o conteúdo principal
Beats Solo 2 Wireless Power Button Replacement
O que você precisa
  1. Beats Solo 2 Wireless Power Button Replacement, Power Button: passo 1, imagem 1 %32 Beats Solo 2 Wireless Power Button Replacement, Power Button: passo 1, imagem 2 %32 Beats Solo 2 Wireless Power Button Replacement, Power Button: passo 1, imagem 3 %32
    • Insert an opening pick in the seam between the right outer speaker casing and the speaker housing.
    • Slide the pick around the perimeter of the casing until the casing releases entirely from the speaker housing.
    • If you encounter any resistance, continue to pry along any spots where the seam is still close together.
    • Failure to loosen the seams may result in the piece breaking partially or completely during removal.
  2. Beats Solo 2 Wireless Power Button Replacement: passo 2, imagem 1 %32 Beats Solo 2 Wireless Power Button Replacement: passo 2, imagem 2 %32
    • Remove the right outer casing.
  3. Beats Solo 2 Wireless Power Button Replacement: passo 3, imagem 1 %32 Beats Solo 2 Wireless Power Button Replacement: passo 3, imagem 2 %32 Beats Solo 2 Wireless Power Button Replacement: passo 3, imagem 3 %32
    • Use a Phillips screwdriver to remove the 2.8 mm screw on the outer shell of the headphones.
  4. Beats Solo 2 Wireless Power Button Replacement: passo 4, imagem 1 %32
    • Remove the power button with your hand or a spudger by prying out the end that is still attached.
    • Beware of the sponge piece when putting the power button assembly back together.
Conclusão
Uma outra pessoa concluiu este guia.
Victor Diuno
Membro desde: 04/02/24
145 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-1, Harley Spring 2024 Membro de IUPUI, Team 2-1, Harley Spring 2024
IUPUI-HARLEY-S24S2G1
4 Membros
Autoria de 3 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 39
Ao todo: 651
