Ir para o conteúdo principal
Beats Solo 2 Wireless Motherboard Replacement
O que você precisa
  1. Beats Solo 2 Wireless Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Beats Solo 2 Wireless Motherboard Replacement, Motherboard: passo 1, imagem 2 %32 Beats Solo 2 Wireless Motherboard Replacement, Motherboard: passo 1, imagem 3 %32
    • Insert an opening pick in the seam between the left outer speaker casing and the speaker housing.
    • Slide the pick around the perimeter of the casing until the outer casing releases entirely from the speaker housing.
    • Failure to loosen the seams may result in the piece breaking partially or completely when removing.
  2. Beats Solo 2 Wireless Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the right outer casing with your hand.
  3. Beats Solo 2 Wireless Motherboard Replacement: passo 3, imagem 1 %32
    • Use tweezers to remove the tape from the motherboard.
    • Loosen the wires from the casing with tweezers.
    • The wires attached to the shell are pinched together in a piece of plastic that will be difficult to remove
  4. Beats Solo 2 Wireless Motherboard Replacement: passo 4, imagem 1 %32 Beats Solo 2 Wireless Motherboard Replacement: passo 4, imagem 2 %32
    • Use a Phillips screwdriver to remove all four of the 4.25 mm screw that secure the motherboard.
  5. Beats Solo 2 Wireless Motherboard Replacement: passo 5, imagem 1 %32 Beats Solo 2 Wireless Motherboard Replacement: passo 5, imagem 2 %32
    • Disconnect all of the motherboard connectors.
    • Do not pull on the wires.
  6. Beats Solo 2 Wireless Motherboard Replacement: passo 6, imagem 1 %32
    • Lift the motherboard up and out of the housing.
Conclusão
Uma outra pessoa concluiu este guia.
Cooper Truong
Membro desde: 04/02/24
277 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-1, Harley Spring 2024 Membro de IUPUI, Team 2-1, Harley Spring 2024
IUPUI-HARLEY-S24S2G1
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 12
Últimos 30 dias: 12
Duração total: 80
