Ir para o conteúdo principal
Beats Solo 2 Wireless Earpads Replacement
O que você precisa
  1. Beats Solo 2 Wireless Earpads Replacement, Earpads: passo 1, imagem 1 %32 Beats Solo 2 Wireless Earpads Replacement, Earpads: passo 1, imagem 2 %32 Beats Solo 2 Wireless Earpads Replacement, Earpads: passo 1, imagem 3 %32
    • Set the headphones down on a flat surface.
    • Insert a plastic card or opening pick between between the earpads and the speaker housing.
    • Carefully pry around the entire perimeter of the the pads until they fully release.
  2. Beats Solo 2 Wireless Earpads Replacement: passo 2, imagem 1 %32
    • Use the card to clean up the adhesive residue left on the headphones.
    • Apply high-concentration isopropyl alcohol to a cloth and use it to remove any lingering adhesive.
  3. Beats Solo 2 Wireless Earpads Replacement: passo 3, imagem 1 %32
    • Fold the other side of the headphones you are not working on.
    • This makes it easier to work and focus on the side you are on.
    • Carefully pick up the new pads and line them up with the Beats.
    • The new earpads come with the adhesive on them already; you just have to peel the plastic covering off.
  4. Beats Solo 2 Wireless Earpads Replacement: passo 4, imagem 1 %32
    • Press down on the new pad to make sure it adheres to the headphones.
    • Make sure to go around the pad and press down on every part.
  5. Beats Solo 2 Wireless Earpads Replacement: passo 5, imagem 1 %32
    • Find a large object and place the headphones on it just like the object is wearing the headphones.
    • Leave the headphones on the object for an hour so it can clamp the earpads to itself.
    • After 1 hour, you are good to go.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Ayotunde Dada
Membro desde: 01/11/24
283 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 39
Duração total: 455
