Ir para o conteúdo principal
Beats Solo 2 Wireless Battery Replacement
O que você precisa
  1. Beats Solo 2 Wireless Battery Replacement, Battery: passo 1, imagem 1 %32 Beats Solo 2 Wireless Battery Replacement, Battery: passo 1, imagem 2 %32 Beats Solo 2 Wireless Battery Replacement, Battery: passo 1, imagem 3 %32
    • Insert an opening pick in the seam between the right outer speaker casing and the speaker housing.
    • Slide the pick around the perimeter of the casing until the casing releases entirely from the speaker housing.
    • Failure to loosen the seams may result in the piece breaking partially or completely during removal.
  2. Beats Solo 2 Wireless Battery Replacement: passo 2, imagem 1 %32 Beats Solo 2 Wireless Battery Replacement: passo 2, imagem 2 %32 Beats Solo 2 Wireless Battery Replacement: passo 2, imagem 3 %32
    • Remove the right outer speaker casing.
  3. Beats Solo 2 Wireless Battery Replacement: passo 3, imagem 1 %32 Beats Solo 2 Wireless Battery Replacement: passo 3, imagem 2 %32 Beats Solo 2 Wireless Battery Replacement: passo 3, imagem 3 %32
    • Use tweezers to disconnect the battery connector from the circuit board.
    • Do not pull on the wires.
  4. Beats Solo 2 Wireless Battery Replacement: passo 4, imagem 1 %32 Beats Solo 2 Wireless Battery Replacement: passo 4, imagem 2 %32 Beats Solo 2 Wireless Battery Replacement: passo 4, imagem 3 %32
    • Use an opening pick to gently pry up the battery.
    • The battery is secured in the housing with adhesive. You can apply some high-concentration alcohol beneath the battery to help loosen the adhesive.
    • Avoid bending or puncturing the battery.
  5. Beats Solo 2 Wireless Battery Replacement: passo 5, imagem 1 %32
    • Lift the battery up and out of the chassis.
Conclusão
Uma outra pessoa concluiu este guia.
Cooper Truong
Membro desde: 04/02/24
280 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-1, Harley Spring 2024 Membro de IUPUI, Team 2-1, Harley Spring 2024
IUPUI-HARLEY-S24S2G1
4 Membros
Autoria de 3 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 64
Ao todo: 547
