Ir para o conteúdo principal
Beats Pill XL Motherboard Replacement
O que você precisa
  1. Beats Pill XL Motherboard Replacement, Case: passo 1, imagem 1 %32 Beats Pill XL Motherboard Replacement, Case: passo 1, imagem 2 %32
    • Using a plastic opening tool, pry the casing from the rest of the device.
    • Pry all the way around the edge and then pull apart.
    • It should be relatively easy, to pull apart. Don't be afraid to apply a necessary force.
  2. Beats Pill XL Motherboard Replacement: passo 2, imagem 1 %32
    • Using your thumb, remove the 8 rubber plugs in order to get to the screws.
    • Simply rub them towards the speakers and they will slide out enough to grip the edge and pull them out.
    • In the picture provided, we labeled four of them on one side of the Beats Pill XL. The other four are symmetrical to these four on the other side of the device.
  3. Beats Pill XL Motherboard Replacement: passo 3, imagem 1 %32 Beats Pill XL Motherboard Replacement: passo 3, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the 8 (10mm maxi-loc Phillips #2) screws that hold the casing together.
  4. Beats Pill XL Motherboard Replacement: passo 4, imagem 1 %32 Beats Pill XL Motherboard Replacement: passo 4, imagem 2 %32
    • Pull apart the front casing from the back casing, slowly. Try to avoid any tension on any of the connected cables.
    • Separate at a slow constant force to avoid damage to the ribbon cables.
  5. Beats Pill XL Motherboard Replacement: passo 5, imagem 1 %32 Beats Pill XL Motherboard Replacement: passo 5, imagem 2 %32
    • Gently pull on the plastic tab at the base of the ribbon cable to remove it from the motherboard.
    • Never pull the cables by the cord, as this could cause damage to the cables and/or motherboard. Always disconnect the cables from the base by the motherboard.
  6. Beats Pill XL Motherboard Replacement: passo 6, imagem 1 %32 Beats Pill XL Motherboard Replacement: passo 6, imagem 2 %32
    • Using your thumb and index finger, pull upwards on the base of the the power cable to remove it from the motherboard.
    • Even though there are two batteries, there is only one cable connecting the two to the motherboard.
  7. Beats Pill XL Motherboard Replacement, Motherboard: passo 7, imagem 1 %32
    • After completing the guide for removing the case, remove the cables connecting the speakers.
    • Simply pull up on them without pulling on the wires themselves.
  8. Beats Pill XL Motherboard Replacement: passo 8, imagem 1 %32
    • Set the half of the device containing speakers to the side.
  9. Beats Pill XL Motherboard Replacement: passo 9, imagem 1 %32 Beats Pill XL Motherboard Replacement: passo 9, imagem 2 %32
    • Remove all five remaining connectors on the motherboard.
    • Do not remove the Bluetooth antenna in the bottom right corner of the motherboard.
  10. Beats Pill XL Motherboard Replacement: passo 10, imagem 1 %32 Beats Pill XL Motherboard Replacement: passo 10, imagem 2 %32
    • Remove the chip for the Bluetooth antenna located to the top right of the motherboard.
    • The other end of this chip is connected to the motherboard via the Bluetooth antenna. Be careful not to tug on that end for any reason.
  11. Beats Pill XL Motherboard Replacement: passo 11, imagem 1 %32 Beats Pill XL Motherboard Replacement: passo 11, imagem 2 %32
    • Using a Phillips #2 screwdriver, unscrew the 4 (8mm pan head Phillips #2) screws holding the motherboard onto the case. They are located in the four corners of the board.
  12. Beats Pill XL Motherboard Replacement: passo 12, imagem 1 %32 Beats Pill XL Motherboard Replacement: passo 12, imagem 2 %32
    • Using both hands, gently lift the motherboard from the case.
    • You have successfully removed the motherboard.
    • Be sure to put the board somewhere it will be safe when it is not being worked on.
Conclusão
14 outras pessoas executaram este guia.
Michael
Membro desde: 03/11/15
659 Reputação
Autoria de 2 guias
Equipe
5 comentários
Disculpe la molestia quisiera saber el número de parte de los transistores Q2,Q3
Armando Artega - Responder
I have a question regarding the contents of circuit.
which type of IC is used in the circuit which is hided by a marker. And if you have that ic than how can i contact you.
Ravi Makwana - Responder
I need the Beats Pill XL Motherboard.. where i can buy
Petrus Damianus G - Responder
Bonjour impeccable bien expliqué
Ou puis-je trouvé cette carte
Merci beaucoup
Gilbert Rodrigues - Responder
0967197831 este es mi movil nesecito saber cuanto cuesta la placa de este beatspill xf ayudeme
Stalin Salavarrialoor - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 39
Duração total: 10,763
