Introdução
Involves opening the case, removing ribbon cable from motherboard, removing four screws, prying off the 'b' button from the hardware and replace with new 'b' button.
O que você precisa
Using a plastic opening tool, pry the casing from the rest of the device.
Pry all the way around the edge and then pull apart.
