Introdução
This guide will serve as a reference on how to replace the speakers on the Beats Pill 1.0. In order to follow this guide, you will need to have the Beats Pill partially disassembled. We would recommend going through our general disassembly guide for guidance on how to disassemble the Pill. For this guide, we will assume that you have fully disassembled the product according to our general disassembly guide.
O que você precisa
Using the spudger, create space between the speaker covers and then remove.
On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
Remove the two screws with a Phillips #0 screwdriver.
Slowly remove the center band and two clip rings until the adhesive separates. Sit to the side the clip rings and the center band
Use the spudger to pry the device apart along its seam, starting in the middle.
Open the device to separate the front and back panels.
Carefully remove the yellow, red, black, and white wires from the motherboard.
Using the Phillips #0 screwdriver, unscrew the two screws that holds the speakers down.
9 outras pessoas executaram este guia.
10 comentários
Do you have a link to the speakers that are used for the speaker pill, the current one seems to be broken and I cant find the replacements anywhere
Just wanted to add a comment regarding where to find the actual replacement speakers for the Beats Pill 1.0. I quite certain that the over all size of each individual speaker is 1" including the plastic bezel around the speaker. The actual size of the speaker itself is 3/4" and I believe I have found a replacement speaker to use if one of the speakers in your Beats Pill 1.0 gets blown or damaged. Below is the link to the replacement speaker, found on www.partsexpress.com. It looks almost identical to the stock speaker installed in the Pill 1.0, minus the custom bezel around the speaker that is used to secure the speakers inside the Pill.
http://www.parts-express.com/tymphany-pm...
Buying all 4 speakers at once saves you 75 cent compared to the price of buying just a single speaker.
Hope this helps anyone looking for replacement speakers for their Beats Pill 1.0
I just got all 4 new speakers to replace the older ones as the rubber rims have all soften and sort of disintegrated/damaged. Only problems with the replacement speakers plastic body are not same as original ones. So the speakers won’t fit the 2 clips, so almost no way to secure the speakers. Probably need to be Super glue.
Victor -
I plugged my speaker in because it needed a charge and the metal piece inside the speaker went into it help
