Ir para o conteúdo principal
Beats Mixr Headband Replacement
O que você precisa
  1. Beats Mixr Headband Replacement, Remove the caps on the headband: passo 1, imagem 1 %32
    • Use a spudger or prying tool to remove the cap on both sides of the headband by applying pressure where the cap meets the band. Next, you will need a Phillips head #00 screwdriver to remove the screws and washer. Twist the screwdriver into the screw and pull it apart from the washer when it becomes loose.
  2. Beats Mixr Headband Replacement, Separate the ear cuff from the headband.: passo 2, imagem 1 %32
    • Begin by pulling the two parts of the headband away from each other slowly and make sure not to break any wires. The wires will now slide free of the headband.
Conclusão
29 outras pessoas executaram este guia.
Allie Horton
Membro desde: 10/08/14
929 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-11, Donnelly Fall 2014 Membro de USF Tampa, Team 1-11, Donnelly Fall 2014
USFT-DONNELLY-F14S1G11
1 Membro
Autoria de 3 guias
3 comentários
Started to disassemble my Mixr. After removing the covers I found the screws not so easy to remove as stated. For one, they must have used lock tite. In addition the nut and screw are so tight a screw driver will not work. Mine has spanner type nuts. I need to find a wrench that will fit.
Has anyone ran into this.
Robert Schumann - Responder
Did you figure out how to get the screws out without breaking?
simmons4jesus -
The replacement parts listed are for studio not mixr and the colors dont match!
Missy Truth - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 47
Duração total: 14,503
