Ir para o conteúdo principal
Beaded Bracelet Clasp Replacement
O que você precisa
  1. Beaded Bracelet Clasp Replacement, Beaded Bracelet Clasp: passo 1, imagem 1 %32
    • From the left end of the bracelet, string on a crimp bead and one end of the new clasp.
    • Bring the clasp and crimp bead 3 inches from the left end of the string.
  2. Beaded Bracelet Clasp Replacement: passo 2, imagem 1 %32
    • Loop the left end of the string through the left side of the crimp bead.
  3. Beaded Bracelet Clasp Replacement: passo 3, imagem 1 %32
    • Push the crimp bead up close to the clasp.
    • Push the crimp bead up as close as you can to the clasp.
  4. Beaded Bracelet Clasp Replacement: passo 4, imagem 1 %32 Beaded Bracelet Clasp Replacement: passo 4, imagem 2 %32
    • Use the bead crimp tool to squeeze the crimp bead shut.
    • Use scissors to cut off excess string.
  5. Beaded Bracelet Clasp Replacement: passo 5, imagem 1 %32
    • Bead the bracelet from the right end.
  6. Beaded Bracelet Clasp Replacement: passo 6, imagem 1 %32
    • After all beads are on, string on a crimp bead and then the other end of the new clasp.
  7. Beaded Bracelet Clasp Replacement: passo 7, imagem 1 %32
    • Loop the right end of the string through the right side of the crimp bead.
  8. Beaded Bracelet Clasp Replacement: passo 8, imagem 1 %32
    • Pull on the string to tighten the bracelet.
    • You do not want the beads spread out.
  9. Beaded Bracelet Clasp Replacement: passo 9, imagem 1 %32 Beaded Bracelet Clasp Replacement: passo 9, imagem 2 %32
Conclusão
Kelly
Membro desde: 03/22/16
182 Reputação
Autoria de 1 guia
Equipe
2 comentários
Awesome!! Its very beautiful [|bracelets] each step make this bracelets so easy. Thank you!! Keep it up
daniel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 39
Duração total: 2,456
